Help! Farmall H not running smooth
Posted by Aaron B on August 13, 2007 at 09:59:01 from (68.117.103.0):
I just completed rebuilding my first engine, it's on a 1941 Farmall H. Got it all back together and it fired right up. Only thing is, it won't 'smooth' out. All 4 plugs are firing. Has new plugs, wires, cap, rotor, points, condensor. I didn't rebuild the carb since it was/is in excellent working condition. New sleeves, pistons, rings, and a complete head job. I set the tappet clearance at .017 and the points at .020 I can advance and retard the timing until it begins to stall, but there is no location inbetween where it runs smoothly. I have an even 88lbs compression across the board. I am really beginning to get frustrated, and would greatly appreciate any fresh ideas or insights that you all may have. Thanks! Aaron
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
