Re: Farmall B - Valves
Posted by Dave H (MI) on August 13, 2007 at 19:22:21 from (205.188.116.73):
In Reply to: Farmall B - Valves posted by Dave H (MI) on August 13, 2007 at 17:39:22:
Hmmm....maybe I will hold off on that alternator check until I get a new (real) switch on there that will not leak current every time it gets a little damp out. Thanks guys.
When you say "sweet spot" in regards to the idle, are you talking about an adjustment to the carburetor or are you talking about tweaking the position of the distributor? I am SOOOO close! If I could get it to to idle without all that stuttering and just tick along quietly it would be really great. Like I said before I am going to check the screens, tighten all the carb connections and carefully play with the idle screw to see what happens but if there is another trick out there, hit me with it and I will give it a try. Thanks guys!
