I don't think you can make the lift cylinder act as a one-way. Look in the area at the bottom end of the cylinder. You should find some linkage there with a pin that can be removed to allow the hitch to float. Also, the bottom of the left lift link has a pin and a "block" that can be repositioned to allow some independent floating of one side. This info is based on a two point hitch with Tele-Depth. Go to www.caseih.com and follow "Search for Parts" there you can find the parts breakdown for the tractor. It may help to see how it works. K-Mo
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
