Re: Synthetic Oil ok for an M?
Posted by Ebbsspeed on August 14, 2007 at 11:46:08 from (70.252.130.253):
In Reply to: Synthetic Oil ok for an M? posted by zooeyhall on August 14, 2007 at 11:24:21:
Yes it's OK to use synthetic in them, and a multi-grade is OK as well. Words of caution! You mentioned overhaul this fall, and one thing you don't want to do is run the synthetic as a break-in oil. It's so slippery that it actually will prevent the rings from seating properly, so your break-in oil should be that good old dinosaur blood that we pump out of the ground. Once the motor is broken in you can switch to the synthetic.
