Re: Need Advice Super A
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Kent on February 13, 2000 at 17:28:22 from (199.120.115.253):
In Reply to: Need Advice Super A posted by Mike on February 13, 2000 at 07:07:39:
Mike,
These tractors were made to run under load all day in the field. If you are running it for short periods of time in cold weather, its not getting hot enough to keep the engine burned out clean. If it runs OK, I would suggest you give it a good workout this spring before you worry about tearing it down. Also, don't tear it down before you have an idea of what it needs. Do a compression check, does it consume oil, does it hit on all four, does it knock or rattle??
Good Luck,
Kent
Post A Followup
: Re: Re: Need Advice Super A
