Vertical distributor on H
Posted by r4etired on August 14, 2007 at 18:59:52 from (64.12.116.73):
Anyone know if the vertical distributor used by MandW that is ahead of the hydraulic pump is the same one that was used on H,s and M,s when they were converted from a mag. The one I have to repair appears to be shorter than the verticals I've seen. You know its time for fixin when the bushing is so bad the rotor catches on the cap and twists it at the rivet.
