Re: multispark problem
Posted by Bob on August 14, 2007 at 19:38:51 from (69.178.229.154):
In Reply to: Re: multispark problem posted by noidea on August 14, 2007 at 19:14:55:
Ignition "ON", Points "open"... check the voltage at the distributor's primary terminal with a digital voltmeter.
Then, rotate the engine so the points are "closed", then check the voltage again.
What do you see?
