Re: 2 way hydraulic valve
Posted by Steven f/AZ on August 15, 2007 at 07:13:06 from (216.67.213.217):
In Reply to: 2 way hydraulic valve posted by Carden on August 14, 2007 at 16:53:58:
If you are going through the trouble of adding a double-acting valve (is that the correct terminology?) personally, I would put a two-spool valve on it right away. This is what I have on my H - I can leave my mower hydraulics hooked up and still hook on a trailing implement. The same principle would apply for a tractor with a 3-point hitch or any mounted implement that needs hydraulics...
third party image[/img]
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
