1950 C oil pan question
Posted by Johnny D on August 15, 2007 at 10:47:01 from (65.183.107.231):
the bolt holes on the front corner of the block for the oil pan appear that they are partially stripped but there is thread up in the top which will a longer bolt will hold. It doesn"t appear to have been drilled since there are no visible signs of treads at the lower side of the hole. I have some longer bolts which came out of those holes so I am asuming that this is normal? Or were all the oil pan bolts supposed to be the same length and the bolt holes threaded from top to bottom?
