Re: tires for 300
Posted by old on August 15, 2007 at 11:15:59 from (4.244.218.223):
In Reply to: tires for 300 posted by Pat-CT on August 15, 2007 at 10:02:05:
12,4X38s work real well on the 300 and the 13.6X38 will also but will speed it up just a bit. All depends on what you want out of it. If you don't mind a little fast ground speed the 13.6 is good but if you want a little slower the 12,4 works well. You do need to make sure your rims are wide enough for either one. I think if I remember right you need a min. of 10 inch rims for the 12.4 and 11 or 12 inch for the 13.6
