Posted by Janicholson on August 15, 2007 at 17:19:42 from (66.173.50.167):
In Reply to: noise posted by deane ferrish on August 15, 2007 at 07:57:04:
If the "clunk" happens a few times a second, it is probably one or more broken teeth in the tranny. Fifth is a coupling direct drive through the input shaft to the output shaft, but fourth is on that fork. I would first pull the belt pully, or belt pulley port cover if no belt pulley, and look at the gears from there. the oil may cover much of what you see, so draining firat, and letting it drip off for a day might enhance your view. Both the driven and coast side of every tooth needs to be looked at. Not all the gears can be seen from the pully opening. If fourth is clicking, and chipped, I would fix it pronto. Reverse might incline me to put it off unless it is used in reverse a lot (loder etc.) JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
