Posted by Janicholson on August 15, 2007 at 17:33:39 from (66.173.50.167):
In Reply to: old farmall governor posted by tom wiseman on August 15, 2007 at 14:02:14:
Tom, I'd wager you have an H or an M Farmall. If there is a tube running from the governor to the carb, front to back, that is probable. There are three things that can affect the tractor as described. One is a disconnected throttle linkage from the hand lever to the governor lever in back of the governor. Check this first. The hand lever should pull the governor lever all the way it can travel when wide open. Adjust it to do so. (springs and nuts on a threaded rod left side of engine) If this does not fix it, the next place to look is the prongs and tabs inside the tube leading to the carb from the governor. Two prongs on the shaft, and one on the carb throttle shaft. they must be interlocked, and are tricky to get correct. If it still has no throttle response it is probably inside the governor. Book needed!!! but doable in every way. JimN
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
