Re: 450 carb adjustment
Posted by old on August 15, 2007 at 21:22:32 from (4.244.6.242):
In Reply to: 450 carb adjustment posted by Chipper on August 15, 2007 at 19:55:11:
Main jet should be set around 4 or 5 turns out from bottom. Then from there you adjust to get the most power with out black smoke
