Re: 504 hydraulic fluid
Posted by Bill Thompson on August 16, 2007 at 11:57:56 from (204.13.113.189):
In Reply to: 504 hydraulic fluid posted by critty on August 15, 2007 at 05:44:10:
I have a 504 and it takes about 12 to 15 gallons. I put in trans-hydraulic fluid which is $13.00 2 gal. at the local farm & feet. It is all in one. One thing you need to know is if you can only shift into two gears you take the shifter out and line up the 3 or 4 nocthes ( it is also easy to fill trans fluid in that spot)and put shifter back. I welded the end of the shifter to make it fit tighter and have not had a problem. Bill Thompson
