Re: IH 424 Brakes are too grabby
Posted by IH2444 on August 16, 2007 at 19:02:45 from (71.171.1.191):
In Reply to: IH 424 Brakes are too grabby posted by Chris Hibbert on August 16, 2007 at 18:49:42:
Use about 80 grit sandpaper on the metal surfaces and the disc surfaces. also grease the balls and tracks slightly in the acutator.
It does not have oil on the discs does it ? sort of common on that side being right below the remote valves.
