Re: 1066 Cl Pedal
Posted by Cor Braakman on August 16, 2007 at 22:47:50 from (84.83.193.235):
In Reply to: 1066 Cl Pedal posted by dwag on August 16, 2007 at 14:47:56:
I've did the same job on my 856. I could reach it by removing the top link of the tractor. If you have long arms you can hold the nut on the inside and turn the shaft on the outside with a player
