Re: Saturday should be the day!
Posted by Bob Kerr on August 17, 2007 at 18:46:26 from (64.12.116.73):
In Reply to: Saturday should be the day! posted by Mike CA on August 17, 2007 at 12:47:31:
Hi Mike, I know you can"t wait to get flying down the road with it and who wouldn"t! Just do me a favor and be sure to grease that front wheel real good! I took my F-12 with that same wheel set up down the road one time to pull a truck out of a ditch and the front wheel locked up on me. happened out of the blue with no noise and I thought I greased it regular enough. seems those need greasing daily! There is NO bearing in there, the wheel rides on the axle shaft, yep, no kidding! I would hate to see you pop it in 5th and have that wheel lock on you. My f-12 only goes 3.5 mph in high so an H in 5th,it would be scary and most likely would break things including bones! I started greasing mine with it moving slow in low and I would pump the gun while walking alongside to make sure grease went in good. Outside of that check her out good and have fun!
