Re: transmission
Posted by Hugh MacKay on August 18, 2007 at 02:58:46 from (216.208.58.101):
In Reply to: Re: transmission posted by Tracy H on August 17, 2007 at 17:35:28:
Tracy: Scott is correct, both counts. The book actually calls for 4 quarts without belt pulley or pto and 5 quarts with. Unless you parked tractor with front end high, when you drained it, plus drained pto, your probably looking at slightly over 4 quarts. I had to remove the pto from my 140 this spring, found I still had oil, jacked front of tractor close to 6" and about another 1/2 quart came out.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
