Re: bush hog, but I use an SMTA to pull it...
Posted by Janicholson on August 18, 2007 at 08:31:50 from (71.87.39.51):
In Reply to: Re: bush hog, but I use an SMTA to pull it... posted by JMOR on August 18, 2007 at 07:24:07:
I think the machine needs blades with the sharp edge on the side closest to the ground. the sharpness should be at an angle of 20degrees or so. I don't know if you can get them with a suction flip up on the back of the blade. JimN
