Posted by El Toro on August 18, 2007 at 16:33:34 from (64.12.116.73):
In Reply to: IH 484 engine is stuck posted by Michael Price on August 18, 2007 at 13:49:31:
If this is a gasoline engine I would pull the sparkplugs to make sure there's no coolant on top of the pistons. If there's no coolant present I would loosen all the bearing caps to see if you can crank it over by hand. Pour some ATF in each cylinder and let it soak. If it still won't turn free I would pull the head to see what the cylinders look like. Hal
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
