Re: IH 484 engine is stuck
Posted by Michael Price on August 18, 2007 at 20:02:50 from (64.12.116.73):
In Reply to: Re: IH 484 engine is stuck posted by Janicholson on August 18, 2007 at 18:43:50:
It has the d-179 diesel 3 cyl engine in it. I bought the tractor from a guy who said the engine was making a noise. I got it home and fired it up and I heard a little knock so I pulled the pan off and seen it spun a bearing. I wanted to start it and see if that was the problem but that was the last time it ran.
