Seat saga continued...
Posted by Mike CA on August 18, 2007 at 23:32:57 from (64.173.170.7):
I dug into the seat problems some more. I thought it was a spring problem like I asked you guys. But playing with it at home I realized the seat falls sideways a bit.
third party image
First, I flipped over the seat pan, since the whole assembly felt a bit loose. I circled what I found alarming. The bolt has been worn more than half way through.
third party image
So I flipped the seat back over and noticed the right side hole had worn open as well.
third party image
Then shook the seat around yo see where else I had movement, and noticed the bolt in front of the spring was loose. So I looked in front and saw this.
third party image
So... What I believe is that I need to replace that tube that everything attaches to, and the bolt that the seat hinges on. Correct? Are they hard to find in good condition?
