Re: Gas tank / Sediment bowl / Gas line
Posted by George K. Clem on August 19, 2007 at 04:36:06 from (67.173.97.188):
In Reply to: Gas tank / Sediment bowl / Gas line posted by Mike CA on August 19, 2007 at 00:41:33:
To clean the tank of rust and varnish (gas residue):
Drain Tank of any liquid, and dispose of as HAZ mat. Can mix wit waste oil and passed on to recycler.
Remove sediment bowl and plug tank.
Add lacquer thinner (carburetor cleaner) with ball bearings or small steel nuts.
Shake tank in all directions to loosen crap in tank. Drain and discard fluid as above.
Repeat process until fluid drains clear.
At this point tank can be pressure washed use soap first.
Alcohol can be used to speed the drying of the tank.
Clean remaining parts of fuel system with lacquer thinner
