Mike, just use a small hose and siphon or as we say in Ky sifer the gas out. Pour it in an open container a gallon or two at a time, and let it sit in your driveway, and soon enough it will evaporate. The will likely need to be taken apart and cleaned goow,then have new o ring installed on the shut off valve. May need a new bowl gasket as well. Good auto parts house will have those. Just look in the new tank with a light and see that there isn't a lot of rust and debris in it. On old bolts and nuts it sometimes helps when removing them to loosen a little and then tighten a little and so on untill it comes out. This helps clean the threads as you go. Now that you own a fine relic, you may want to invest in a thread chaser. They are wonderful to restore old bolt threads. They should fit 8 different size of course and narrow threads.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
