Re: Gas tank / Sediment bowl / Gas line
Posted by John M on August 19, 2007 at 05:35:12 from (209.213.22.170):
In Reply to: Gas tank / Sediment bowl / Gas line posted by Mike CA on August 19, 2007 at 00:41:33:
Before I would do anything to it, I would verify that the sealant was accually the problem. Too many times have I gone by what someone else has said only to find that wasnt the problem.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
