Re: 350 help
Posted by old on August 19, 2007 at 10:33:58 from (4.244.221.237):
In Reply to: 350 help posted by wegman in mn on August 19, 2007 at 10:09:03:
In most cases you can replace the bearings with out taking out the crank shaft, but its not always an easy thing to do or the right way to do it. As far as the crank you have to slip the tractor to remove it and any time you are replacing the bears you should have the crank checked and maybe even turned because of wear
