Re: 450 hyraulics?
Posted by SDE on August 19, 2007 at 19:20:44 from (69.179.7.226):
In Reply to: 450 hyraulics? posted by Chipper on August 19, 2007 at 18:43:01:
Did you check to see if the control is set for one way only? If it is set that way, you can reverse the hoses and it should lift it.
A friend has a SMTA and he had 850 if I remember correctly. I believe your pump is about the same.
Maybe as high as 1250, but not positive.
SDE
