Re: Tricks for siphoning gas?
Posted by gene bender on August 19, 2007 at 19:42:27 from (67.55.226.214):
In Reply to: Tricks for siphoning gas? posted by Mike CA on August 19, 2007 at 12:35:18:
Are you sure you have the shut-off valve open? Blow some air into the line and gas should run out. Sooner or later you will have to remove the sediment assy and there is no way you are going to be able to siphon all the gas out so you need to get the gas flowing thru the sediment assy.
