Re: Tricks for siphoning gas?
Posted by Mike CA on August 19, 2007 at 21:29:49 from (64.173.170.7):
In Reply to: Tricks for siphoning gas? posted by gene bender on August 19, 2007 at 19:42:27:
gene bender said: (quoted from post at 19:42:27 08/19/07) Are you sure you have the shut-off valve open? Blow some air into the line and gas should run out. Sooner or later you will have to remove the sediment assy and there is no way you are going to be able to siphon all the gas out so you need to get the gas flowing thru the sediment assy.
I was told the reason the tractor stopped running was because the sealent had made it's way down out of the tank and clogged up the works.
The sediment bowl I have is a single line variety, and I want to put the starter tank back on it and run the line, even though I don't actually plan on using it, it's still a good conversation piece.
