Re: will not crank after engine overhaul without a shot of e
Posted by rockwood84 on August 19, 2007 at 20:30:26 from (209.215.58.238):
In Reply to: Re: will not crank after engine overhaul without a shot of e posted by MN Scott on August 18, 2007 at 19:57:26:
new pistons, rings, sleeves ,bearings, and head reworked all of it was $ 3000.00. but the throttle linkage is off from what it used to be to crank it you have to move throttle to high, as before it would crank 1/2 way over. and the kill is an inch over from slow, before it would kill below slow all the way to leftside.but the injector pump has not had anything done to it for twenty years probably time for a rebuilt or new one. thanks
