Re: 450 hyraulics?
Posted by Brownie450 on August 20, 2007 at 16:03:22 from (207.177.82.240):
In Reply to: 450 hyraulics? posted by Chipper on August 19, 2007 at 18:43:01:
Hydraulic check is a square plug on the right side of the hydraulic box. Screen is at bottom of the hydr. box with 4 5/16 bolts holding it in. Maybe 3/8 on the bolts. If the Hy-tran hasn't been changed in a while, the screen could be collapsed. Ours ran 1500 lbs on a new pump, & 1200 on an aged one. That's a lot of disc to lift. By the bye--- how big is your cylinder? Should be 4" or more.
