Daniel: No I don't have a photo, nor do I have one. I do have a device on front of my 140 for mounting a dry chemical applicator, high enough so material flows just ahead of center mount planter. The base is a 3" chanel iron box frame going back under front axle to just below those tabs on back of cultivator mount. It is the same width as those tabs with vertical links going to the tabs on each side, then it has a heavy brace up to right side of clutch housing. It has a vertical frame about 8" in front of tyrods. It is mounted just enough below axle to allow it to pivot without striking frame.
I carries my applicator, I use it for mounting front end weight when needed. I have pushed out a few fence posts with it, pushed a few vehicles. It's still the same shape as when I built it, however if I were doing it again with bumper in mind as well as the uses I make, I'd build it with 4" chanel. I can leave this mounted when using cultivators.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
