Re: Farmall Super M - Carb Problems
Posted by Andy Motteberg on August 20, 2007 at 18:07:35 from (4.143.221.151):
In Reply to: Farmall Super M - Carb Problems posted by Farmall Man on August 20, 2007 at 18:04:19:
Is the float level set right and is the carb to manifold gasket good and bolts tight?
