Re: Cub w/ External Coil and Mag
Posted by john *.?-!.* cub owner on August 20, 2007 at 20:18:05 from (69.179.186.78):
In Reply to: Cub w/ External Coil and Mag posted by Bob Kerr on August 20, 2007 at 08:24:42:
Some coils have an internal resister, and run directly off 12 volts. first get it going with the coil,. probably points or condenser. then more than likely all you will need to do is replace the internal mag coil. Teh switch on a mag grounds it to kill it, so you will need a different one for that.
