Re: Farmall 806- torque converter/amplifier or compression p
Posted by K.B.-826 on August 20, 2007 at 20:26:30 from (68.190.155.36):
In Reply to: Re: Farmall 806- torque converter/amplifier or compression p posted by Armand Tatro on August 20, 2007 at 20:12:56:
806 TA should NOT freewheel at all. If it does, it is junk, the low side brake pack is fried and the unit needs to be replaced. The mechanical TA's will freewheel when the lever is back. Remember, if the tractor has the 5-speed transmission, it has the mechanical TA. If it has the 4-speed with high/low or the 3-speed with high/low, it has the hydraulic TA which should NOT freewheel.
