450 LP problem
Posted by Albert Pereira on August 21, 2007 at 18:45:34 from (205.188.116.73):
Hello, I got the farmall running after an ignition tune up and two no fouls. When its working it seems to burn lots of oil, I know she is getting tired but It still ran good enough to pull a mower and a small 14 ft disc. it started to run like it was out of fuel, loosing power and sputewring a little. I parked filled it up and now it just turns over and wont start. It has fire.seems like if I choke it a little it fires one or two times and just spins. Dont know much about the LP system. Is there someone that sells rebuild kits for the carb and regulator? Is this where you think the problem is? I was going to try and start it on either to see if it would have enough Vacuum when running to keep it going. Not sure what to do. Thanks for all your help
