Re: H Hand Crank Problem
Posted by glennster on August 21, 2007 at 19:14:04 from (68.60.242.156):
In Reply to: H Hand Crank Problem posted by Doug Kieta on August 21, 2007 at 19:08:05:
see if you have the mud shield on the underside of the bolster. it is a tin shield that keeps the mud from packing in the bottom of the bolster. if its not there the starting asem is probably packed with years of mud and debris. clean alll the junk out with a scraper, compressed air and then pressure wash it.after its clean, spray it up real good with pb blaster penetrating oil. you will probably need to spray some every day for a few days, keep working the crank, tap it with a rubber mallet, it should loosen up.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
