H Hand Crank Problem
Posted by Doug Kieta on August 21, 2007 at 19:08:05 from (24.179.37.155):
The hand crank on my 51H will not work because the cylindrical dog that engages the front pully is frozen in the bolster support casting and will not allow itself to be pushed in to engage the pully. Is there some way to get the hand crank assembly apart without tearing down the front of the tractor? Only way I can figure is to take off the radiator and the front bolster and then remove the support casting from the side rails so it can be worked on in the vertical position. Lots of work if there is, in fact, and easier way to loosen the cylindrical dog up.
Suggestions?
