Posted by Janicholson on August 21, 2007 at 19:17:44 from (71.87.48.78):
In Reply to: H Hand Crank Problem posted by Doug Kieta on August 21, 2007 at 19:08:05:
Heat and penetrant and heat with a wt hanging on the crank handle while attached to the crank snout. The wt should be about 100lbs and the crank should be sideways. if the crank is not in a good position, use a pipewrench on the snout to gain that horizontal position for the wt. Then more patience and heat and penetrant. then tapping the end of the snout with a hardwood block and a 2lb hammer then heat and patience. Taking it apart would help spend time, not make it easier. JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
