Re: Farmall Super M - Carb Problems
Posted by Farmall Man on August 21, 2007 at 19:36:39 from (209.94.180.143):
In Reply to: Re: Farmall Super M - Carb Problems posted by Bob M on August 20, 2007 at 18:19:21:
Seems like starts running ok cold, but then as things heat up, and it stumbles in the field, and I back off the throttle, let it smooth out, and then it can"t even pull itself..
The float is level, and tight, no leaks... carb looks clean and all fittings inside/jets are tight... I did take it off and put it back on... but it was tight coming off.. so that doesn"t seem to be it.
I do have 30 weight oil in air cleaner bowl, so it looks per the book, that I should change it to 10 weight. maybe too much air restriction??
I found the points, and condensor rusted up bad, and distributor full of dirt/rust... and now the plugs are fouled, so just put plugs, and points and condensor in... The points are set at .023", so I can tighten those up a bit.. I can also check timing.. and check for play for distributor rotor, and look for timing advance, and will check governor... I got it running but it was missing so have not had a chance to try it again... not sure why it was missing, unless it is the point gap..
So going to check spark on all the wires next, confirm timing.. point gap... just strange that the main jet has to be closed up to run half way decent..
Thanks for any help!
