Have gear count wrote down somewhere but no time to look up this morning. If you look at the transmission counter shaft for the low low the first speed driving gear will be made on counter shaft,(shaft and gear one piece) compared to pressed and keyed on regular first. Since first and second drive gear are one piece in regular tractor, second in low low is a seperate gear but same ratio. First and reverse sliding gear is bigger so the teeth it engages on reverse idler has to be changed. (whole idler is changed) This ends up making reverse slower also. 3&4 drive gear is changed a little also because of spacing, gear ratio the same unless high speed 4th transmission. couple of other parts used with some set ups also.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
