Re: M - H Compatibility
Posted by georgeky on August 22, 2007 at 08:43:23 from (64.12.116.73):
In Reply to: M - H Compatibility posted by Robert Heft on August 22, 2007 at 08:20:08:
Robert, like Allan mentioned, you need to remove your shifter and see if it has just slipped out of the shifting rail. Is so just take a big screwdriver and slide all rails into the neutral position and put the shifter back in. This is a common problem with old tractors with a million hours on them. If this is all wrong with your M the shifter can be welde up on the end and ground back down to fit the rails much better and cure this problem.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
