Re: Farmall A Magneto/Battery Ignition?
Posted by CNKS on August 22, 2007 at 19:42:33 from (216.144.103.153):
In Reply to: Re: Farmall A Magneto/Battery Ignition? posted by John P. on August 22, 2007 at 17:36:48:
The conversion to distributers did not occur on all models at the same time. I believe it was complete by sometime in 1949, I can be corrected. I don't know if a distributer was even an option when your A was built.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
