Re: Rear Main Leaking
Posted by SDE on August 22, 2007 at 20:06:46 from (69.179.7.226):
In Reply to: Rear Main Leaking posted by SuperCmore on August 22, 2007 at 06:36:05:
When I replaced my ring gear on my C, I jacked it up, supported it with a jack, removed the front end, and then backed my truck under the motor. Did it outside of course. Worked quite well.
SDE
