Re: Farmall 100 steering problem
Posted by scotty on August 23, 2007 at 11:33:42 from (199.231.49.128):
In Reply to: Farmall 100 steering problem posted by Fred In TN on August 23, 2007 at 10:43:11:
Afternoon Fred,
The steering arm is on a taper, so your going to need a small wheel puller or you might be able to pop it off using a steel wedge between the arm and the bottom of the steering box. There is a woodruff key on that tapered shaft, you will want to inspect when you have it apart !
scotty
