560 Fast Hitch Hydraulics
Posted by Robhkent on August 23, 2007 at 13:26:20 from (157.130.169.110):
HELP!!
My 560D, equipped with a fast hitch is giving me trouble.
I use my 560 for builiding fence, and have a Shaver #10 driver on the front. In order to run the driver, I plug the supply line for the driver into the side mount hydraulics (cultivator). I tie down the lever for that spool when I am using the driver.
The problem is that when I am using the driver, the fast htich creeps up or down, and a LOT of oil starts to leak out of the fast hitch block in the tool box. It is not coming out of the hose seals or the pipes going to the hydraulic block, but out between the pieces of the block. I can replace the O rings, but how long will that last?
Do I have an issue in the hydraulic blocks under the dash?
Rob
