Re: 560 Fast Hitch Hydraulics
Posted by a_lead on August 23, 2007 at 15:07:23 from (76.100.35.189):
In Reply to: 560 Fast Hitch Hydraulics posted by Robhkent on August 23, 2007 at 13:26:20:
It's been a long time since I was in front of a 560 set up like yours, but a few things that I remember:
Check to be sure that you have the control for single action/double action cylinder set for single action.
Where do you have the return fluid going back into the reservoir? Possibly where u have the return connected can't take the large volume of oil as fast/hard as it is coming back from the driver.
The one we had when I used it had a large return hose, that the dealer routed back into the reservoir thru the fill hole in the top of the platform. He (dealer) cut a piece of plate steel to match the pattern, brazed a pipe fitting into to connect the return hose.
Hope that this helps.
Edward
