Re: 140 steering box
Posted by Super A on August 24, 2007 at 07:25:33 from (208.1.217.193):
In Reply to: Re: 140 steering box posted by CityBoy-McCoy on August 24, 2007 at 04:07:10:
Cityboy is exactly right. A lot of the wear is at the pitman arm where it attaches to the sector shaft, or between the sector gear and shaft (the parts you are talking about welding.) Very seldom is there enough wear between the worm gear and the teeth on the sector gear to cause loose steering.
Have you priced a new gear/sector shaft lately? If you do you'll see that welding the gear to the shaft is indeed a viable option-- not only is it cheaper and will last longer, it does not affect the appearance of the tractor since it's internal.
Al
