Janicholson: Question about sanding combine engine bore
Posted by chadd on August 24, 2007 at 22:43:57 from (4.188.134.233):
I have a few questions about sanding the bores. Do I just sand the little spots down, or move around the whole bore? Also, when I do sand, should I sand vertically in the bore, horizontally, or at a 45 degree angle? Should I sand until the surface is indestinguishable from the rest of the bore, or just enough that the little spots feel smoother, but still noticeable? Also, is 400 grit acceptable?
Thanks.
