Re: H with no spark
Posted by El Toro on August 25, 2007 at 08:19:21 from (64.12.116.73):
In Reply to: Re: H with no spark posted by vernMN on August 25, 2007 at 07:30:13:
After you tighten the condenser you can check your
distributor for fire by removing the coil wire from the distributor's cap and hold it near a good ground while someone snaps those points open and close a few times. You need the ignition switch on and each time the points are snapped your coil wire should fire. If your coil wire is cracked I would install a new one. Hal
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
